10-21-2015 11:59 AM
I used to be able to save files as PDF's with PDF lite but my HD crashed and I cannot seem to download another version due to security issues. However I have downloaded the Acrobat reader DC but when I try to print (save it as a PDF) that option no longer shows up from the print list. Any ideas?
10-22-2015 03:26 PM
Hi teslac
It seems that Acrobat doesn't works like a print. At least Multisim doesn't took it as an option for printing. If you want i attached the PDF lite installer, so you just need to run it on your computer.
Warm Regards,
10-23-2015 06:44 AM
RE: That did it! Work fine now. Thanks for the down load of PDF lite!
