Multisim and Ultiboard
/\/\/\__ how to edit ISL55110 spice for multisim??
hello, i got this spice from ISL55110, i want to use it in multisim13. it gives me errors about nultiple subckt. what do i do to make it work in multisim 13?
*ISL55110 Spice Model
"* Revision F, Aug 2008"
* Delays now simulated with Delay Lines instead of RC Time Constants
* Models
.model SWOUTN VSWITCH ron=2.83 roff=100Meg von=+.2 voff=-.2
.model SWOUTP VSWITCH ron=2.6 roff=100Meg von=.2 voff=-.2
.model den D (n=1)
.model SWMOD VSWITCH ron=10 roff=100Meg von=+.1 voff=-.1
.model SWHIZ VSWITCH ron=100Meg roff=0.001 von=+.2 voff=-.2
* Components Definitions
*Input PAD
.subckt IN_PAD 1 2
RIN  1  2  100e6
CIN  1  2  1e-12
.ends
* Output PAD (IN GND)
.subckt OUT_PAD 1 2
RIN 1  2  100e6
* CIN should be adjusted  depending on the power down time.(PD time - 10 ns )
CIN 1  2  14e-12
.ends
*Comparator with hysterisis
*COMP_HS IN OUT VDD GND
.subckt COMP_HS 1 2 3 4
* Thresholds
VTHR1 7 4 1.2
VTHR2 8 4 1.4
* VDD/2 Generation
R1 3 9 100e6
R2 4 9 100e6
*Delayed output
R3 2 21 3e3
C1 21 4 0.43e-12
SW1 7 10 21 9 SWMOD
SW2 8 10 9  21 SWMOD
*COMPARISON
SW3 3 2 1 10  SWMOD
SW4 4 2 10 1  SWMOD
.ends
* Buffer Models ( IN OUT VDD GND)
.subckt BUF_X 1 2 3 4
*Generating VDD/2
R1 3 7 100e6
R2 4 7 100e6
SW1 3 2 1 7 SWMOD
SW2 4 2 7 1 SWMOD
.ends
*Level shifter (IN OUT LV_SUPPLY GND HV_SUPPLY)
.subckt LS 1 2 3 4 5
*Gnerating VDD/2
R1 3 7 100e6
R2 4 7 100e6
SW1 5 2 1 7 SWMOD
SW2 4 2 7 1 SWMOD
.ends
* Delay from LV(VDD) components in signal path
* LV comparator and level shifter give a delay of 3 ns(approx).
* T=0.69*R*C Obsolete, use delay line model instead
* Delay_LV IN OUT GND
.subckt Delay_LV 1 2 3
T1 1 3 2 3 Z0=100Meg TD=3n
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
* Delay from HV inverters in the signal path.
"* though this delay vary with supply(VH) , modeled delay as 6 ns ."
.subckt Delay_HV 1 2 3
T1 1 3 2 3 Z0=100Meg TD=6n
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
.subckt DelaY_HV-1 1 2 3
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
*ISL55110 model
*               VDD PD IN_B     IN_A     OA VH GND OB ENABLEZ
.subckt ISL55110    1   2  3          4       5  6  7   8    9
XPAD_INB  3  7 IN_PAD
XPAD_INA  4  7 IN_PAD
XPAD_PD   2  7 IN_PAD
XPAD_ENZ 9  7 IN_PAD
*Input Clamp Diodes for IBIS
d5 7 3 den
d6 3 1 den
d7 7 4 den
d8 4 1 den
d9 7 2 den
d10 2 1 den
d11 7 9 den
d12 9 1 den
R1 1 99 100e6
R2 99 7 100e6
R10 6 199 100e6
R11 7 199 100e6
XCOMP_A  4 10 1 7 COMP_HS
XCOMP_B  3 11 1 7 COMP_HS
XDELAY_LVA  10 12 7  Delay_LV
XDELAY_LVB  11 13 7  Delay_LV
XLEVEL_SHIFTERA  12 14 1 7 6  LS
XLEVEL_SHIFTERB  13 15 1 7 6  LS
XDELAY_HVA 14 16 7 Delay_HV
XDELAY_HVB 15 17 7 Delay_HV
*PD or ENABLEZ
R3 18 7 100e6
SW1 1 18 2 99  SWMOD
*SW2 1 18 9 99 SWMOD
SWA 16 19 99 18 SWMOD
SWB 17 20 99 18 SWMOD
V  210 7 -1
R4 19 210 100e6
R5 20 210 100e6
* OUTPUT SWITCHES
*OA Switch
T1 9 7 230 7 Z0=100Meg TD=15n
R6 230 7 100Meg
SWTPA 6 220 230 99  SWHIZ
SWPA 220 5 19 199  SWOUTP
SWNA 221 5 199 19    SWOUTN
SWTNA 7 221 230 99    SWHIZ
C1 5 7 100pF
d1 7 5 den
d2 5 6 den
XPAD_OUTA 5 7 OUT_PAD
* OB Switch
*HIZ High Side
SWTPB 6 222 230 99  SWHIZ
SWPB 222 8 20 199  SWOUTP
SWNB 223 8 199 20  SWOUTN
*HIX Low Side
SWTNB 7 223 230 99    SWHIZ
C2 8 7 100pF
d3 7 8 den
d4 8 6 den
XPAD_OUTB 8 7 OUT_PAD
.ends
(i think NI should come up with a better component wizard. with the myriad of components and thousands of compatibility issues, we cant use ONLY NI components to make a complete product. while this may only be a simulation environment, and the lack of co-operation between all major manufactureres MAY be a problem, but being unable to take in complex SPICE models is a bad start)
(6,338 Views)
AGAIN ... ANOTHER spice NEED HELP ... BUT I GET NO HELP ....
* PSpice Model Editor - Version 16.3.0
.SUBCKT FDD86102 2 1 3
*Nom Temp 25 deg C
Dbody 7 5 DbodyMOD
Dbreak 5 11 DbreakMOD
Lgate 1 9 5.083e-9
Ldrain 2 5 0.004e-9
Lsource 3 7 2.29e-9
RLgate 1 9 50.83
RLdrain 2 5 0.04
RLsource 3 7 22.9
Rgate 9 6 1.06
* Shielded gate
D_D1         100 5 D_SG_cap
D_D2         100 101 D_SG_cap
R_R1         101 7  3.37
C_C1         6 101  84e-12
.MODEL D_SG_cap D (IS=1e-9 n=1 RS=4.0e-3 CJO=1.2e-9 M=0.6 t_abs=25)
It 7 17 1
Ebreak 11 7 17 7 109.5
Rbreak 17 7 RbreakMOD 1
.MODEL RbreakMOD RES (TC1=0.66e-3 TC2=-0.6e-6)
.MODEL DbodyMOD D (IS=1.0e-12 n=1 RS=4.6e-3 TRS1=3.0e-3 TRS2=1e-6
+ CJO=0.25e-9 M=0.4 TT=3e-9 XTI=4) ;0.75
.MODEL DbreakMOD D (RS=30e-3 TRS1=1e-3 TRS2=1e-6)
Rsource 7a 7 0.971e-3
Rdrain 5 16 RdrainMOD 14e-3
.MODEL RdrainMOD RES (TC1=6.7e-3 TC2=14e-6)
M_BSIM3 16 6 7a 7a Bsim3 W=1.7 L=4.85e-6 NRS=0 NRD=0
.MODEL Bsim3 NMOS (LEVEL=7 VERSION=3.1 MOBMOD=3 CAPMOD=2 paramchk=1 NQSMOD=0
*Process Parameters
+ TOX=1000e-10 ;Oxide thickness
+ XJ=0.62e-6 ;Channel depth
+ NCH=1.2e17 ;Channel concentration
*Channel Current
+ U0=840 VSAT=500000 DROUT=1.8
+ DELTA=0.16 PSCBE2=0.00001 RSH=0.971e-3
*Threshold voltage
+ VTH0=3.33
*Sub-threshold characteristics
+ VOFF=-0.1 NFACTOR=1
*Junction diodes and Capacitance
+ LINT=2.025e-6 DLC=2.025e-6
+ CGSO=196e-12 CGSL=0 CGDO=1e-12 CGDL=165e-12 ;245
+ CJ=0 CF=0 CKAPPA=1.0
* Temperature parameters
+ KT1=-1.8 KT2=0 UA1=3.95e-9
+ NJ=10)
.ENDS FDD86102
(6,289 Views)
I got the same problem.
any help?
(6,264 Views)
I am having the exact same issue. Can some one out there in the community please give some clue as to what needs to be modified or added to make this model simulate?
Thanks!
(3,169 Views)
