03-15-2018 12:35 AM
i started using ultiboard. what i notice is that a holed rounded rectangle not properly showing during preview and printing. kindly check the attached file. anybody can help?
Solved! Go to Solution.
03-16-2018 11:49 AM - edited 03-16-2018 11:51 AM
Hi zackde,
I am looking at it, it seems to be a bug but I have to run some tests to confirm this.
By the time, what version and edition of Ultiboard are you using? And what OS?
José F.
03-31-2018 09:08 AM
hello José F.,
thanks for your reply. i'm using ultiboard 13 in windows 10 x64. 'hope it could resolve or have a work around soon.
thankz,
zackde
04-02-2018 05:02 PM
Thanks for the information!
I will consult with my colleagues at R&D and will post an update as soon as I get more information.
José F.
04-03-2018 03:47 PM
Hi Zackde,
This is an unexpected behavior and was reported to R&D as a bug in CAR # 693366. You can check in further software/patch releases if the issue was fixed using the CAR number.
You can have the files printed by exporting the design in Gerber format, and use a tool to print it or use a Gerber to PDF converter tool and print the PDF.
José F.
04-05-2018 12:02 AM
hello José F.,
again i very much appreciate your immediate reply. your information already noted likewise i already tried your suggestion.
i'll check every now and then for its fix.
thankz,
zackde
