01-11-2017 12:42 PM
Hello everybody,i am an electrical engineer student and we are making a circuit in class.At this circuit we have an oscilator tha we want to make a triangle wave with 35kHz frequency and 0.8 volt p-p.(not from the output of the op-amp(tl074),but from th pin of copacitor.We use this circuit.At class we have as ground the -12 volts.how can i make the same thing at multisim and see it at the oscilloscope?thanks in advance
01-12-2017 01:47 AM
lay out your file from Mul'tisima ...
01-12-2017 01:58 AM
I should take as an exit a triangle wave,at lab with these values i had almost 35k frequensy and almost 3V p-p.I say again that at lab we took as ground -12Volts
01-12-2017 03:55 AM
It should be like this .. ??
01-12-2017 03:59 AM
or so .. ??
01-12-2017 05:21 AM
First of all thanks for your answers but i think tha you have made some changes at the circuit.The circuit is like this picture,at lab i remember that we put 2 smoothing capacitors.I dont know if that thing has to do with wrong asnwer.The thing that iam sure is that real ground is -12 volts and for c=10n,R=.1.22k,R1=100k and the other two resistors 10k each of them that i must have almost 35kHz and 3++ volts p-p with traingle wave
01-12-2017 05:30 AM
Sorry my mistake you are right but you just changed the values.The circuit is right but gives wrong numbers at oscillator.Maybe tha happens bacause i have not put the smoothing capacitors
01-12-2017 08:10 AM
... 35 kHz originate in this configuration ...
01-12-2017 09:08 AM
I really thank you for your time.I have some problems.
1)the big question is:why at lab i had 35Khz with 100k instead of 6.2k?
2)why at lab i had 3.2volts p-p and now i had almost 5?
I am not asking you to answer because i know gia tried a lot to helo but i cant understand what is going on
01-12-2017 09:11 AM
this is the exactly pdf that our university has given to us about the op amp
