09-16-2012 11:36 AM
I installed Multisim and Ultiboard under programsx86/National Instruments and it said successfully installed. However, when I start eaither program all i get is this (see attached)
09-17-2012 08:12 AM
What operating system are you using? To resolve this issue, you can try the following:
1. Navigate to the windows Control panel
2. Select Uninstall a program
3. Select National Instruments Software
3. Select NI Circuit Design Suite under the products tab
4. Click Repair
Hope this helps.
09-17-2012 12:17 PM
I am using windoes 7 86 bit version. I tried a repair on the circuit design suite and on every program I installed from NI but neither worked. I tried uninstalling then reinstalling only the circuit design suite and then on every NI program neither worked. Could it possibly be that some of the program is installed in a different folder than the one requested by startup? I originally installed the program in a shared folder, but the folder was a bit to small and I uninstalled it. I tried installing it to the program folder in C: and it worked only up to the gray window. Thank you for helping me out by the way.
09-17-2012 02:22 PM
You may have to run the program in Windows XP compatibility mode. You can find out more about this on the Microsoft website.
