11-12-2007 05:54 PM
11-13-2007 11:28 PM
11-13-2007 11:38 PM - edited 11-13-2007 11:39 PM
11-14-2007 04:39 PM
Thanks Chris for the information you posted. I would agree that he needs to review this information so he can learn about the 555 timer and its configurations. This can only help him in his quest to understand designing and electronics even more. I did post a corrected version of his circuit for him and posted sticky notes to the things I changed. The circuit I posted (just in case you would want to look at it) has the correct configuration but I didn't go through all the math to select the resistors. I just arbitrarily selected 2 that would allow the LED to switch fairly quickly so he could see that his circuit did work.
11-22-2007 01:31 AM
11-22-2007 10:30 AM
There is a Help file that should be able to give you this information. Goto HELP>MULTISIM HELP. If you can't find what your looking for in the helpfile then there is a documentation folder within the National Instruments folder that should contain a Getting Started Guide and a User's Manual. These two reference documents should have all the information that you need about these instruments.
