07-10-2007 10:06 AM
07-12-2007 05:30 PM
Usually, virtual components do not have a footprint associated with them, you can assign one if you want to. If the footprint is on the database then try the following:
1. In Multisim, at the spreadsheet view, select the components tab and look for your DPDT component... then go to the Footprint column and click that cell... you will get a dialog to select a footprint... locate your footprint and make sure you map the pins correctly. Your DPDT should change its color from black (virtual) to blue (real).
2. If you do not see your footprint (the one you created) check this articles:
http://digital.ni.com/public.nsf/allkb/364FC33F1DB69255862571B800632DC4
http://digital.ni.com/public.nsf/allkb/B0077C481ED8E47B862572110061FA6B
http://digital.ni.com/public.nsf/allkb/7FCBDE7E249D6CCE8625721400561A51
