11-04-2010 11:58 AM - edited 11-04-2010 12:00 PM
Hi.
I have some few, very basic questions. I am new to Multisim and wonder if there is an option to place different symbols to electric components than the default symbols offered in multisim. I have added an attached file with detailed explanation regarding the components i'm intrested in.
Thanks.
11-05-2010 10:43 AM
Multisim support two symbol standards: ANSI and DIN. To change the standard go to Options>>Global Preferences>>Parts. If the symbol that you need is not available you can use the Component Wizard (Tools menu) to create a custom component.
With regard to your second question, you can add comments, text and graphics to the workspace area. These options can be found in the Place menu.
02-06-2012 10:56 PM
02-07-2012 06:47 AM
IYU,
Go to Edit -> Properties -> Workspace and you can change the sheet size. You can make a really large sheet but if you try to print it, it may become unreadable due to shrinking of the schematic to fit the page. If you have a really large design and want to print it, you should split it up and use off-page connections to tie the various pages together.
A side note: Don't ask a question that really doesn't have anything to do with the original question. Create a new message with the new question. It doesn't cost extra.
