I have not seen one specific for a DC jack connector... however, I think you could probably use the HDR1X2 (that will give you V+ and GND) and just customize the component... use the same symbol... but change the footprint... to your specific DC jack connector you will be using for layout.
Although... you'll still need to place a voltage supply and a ground component connected to it... they will be virtual though... check the image attached, let me know if that works...
