Multisim and Ultiboard
dc jack
hello customer support,
this is just a trivial question but it keeps me stuck !
I cant find symbol for DC jack connector in connector library, multisim 9.0.
may be it comes with a different name ? but cant find it ?
any ideas ?
(5,310 Views)
I have not seen one specific for a DC jack connector... however, I think you could probably use the HDR1X2 (that will give you V+ and GND) and just customize the component... use the same symbol... but change the footprint... to your specific DC jack connector you will be using for layout.
Although... you'll still need to place a voltage supply and a ground component connected to it... they will be virtual though... check the image attached, let me know if that works...
Nestor
(5,305 Views)
