07-15-2008 10:56 AM
07-15-2008 03:00 PM
There is a generic monostable available in Multisim and you can find it in the Mixed group under the Mixed Virtual Family. If you are not sure how to hook up this component have a look at the attached file, the A1 pin is positive edge trigger while A2 is negative, the pulse width is 0.693*RC. I'll be surprise if you are able to find the 4047 model online.
10-05-2008 11:02 PM
hi
you send the file for CD4047 can not be open...
plz send the prefix for the file...
10-06-2008 10:09 AM
It opened for me. I have Multisim 10.1
Howard
06-16-2009 11:13 PM
Hi, this generic model have only 7 pins, in most of the circuits it is 14 pin, can any body please provide the componet for it
thanks
Kami
11-24-2011 10:57 AM
I'm new with this and I also need help with this model. I just found a CD 4047 model for LTspice, can it be converted to a multisim 10 or 11 model?
11-29-2011 02:44 PM
Hi Richard,
The file you attached is not a SPICE model, it looks like a netlist file and you can't use it to create a component.
12-05-2012 09:14 AM
i am using multisim 12.0
i want cd4047
how to get it
it is not included in the library
waiting for your reply
12-10-2012 10:27 AM
This part is not included in the Multisim database. You will need to see if a spice model has been made for this part by the manufacturer. You can check on the manufacturer's website. If you can find a spice model, you can use the article below to make a custom component in Multisim.
http://www.ni.com/white-paper/3173/en
Hope this helps.
04-20-2013 01:06 AM
