Since I have to add a severe bug to the list today, I thought that updating the old list could be a good idea.
First thing first, the bug:
Bug #19: When using the map pins tool, the pin mapping isn't saved properly.
I created a 64 pins part yesterday, and I used the map pins tool. When I finished, the mapping was all properly displayed in the Symbol Pin to Footprint Pin Mapping Table (Footprint tab). I saved the part in the database, and then, all the mapping information was lost. When I re-edited the part, all the mapping was lost, and what's even worse, it contained erroneous data (footprint pins were reattributed in numerical order).
Then, the list. I also seperated it between the features and the bugs:
BUGS
>>2. Tab order messed up
>>I
really wonder how this is possible for a professionnal software such as
Multisim, but the tab order doesn't follow any logic in many forms in
the software
Unknown status.
>>3. Components clearances
>>We NEED the
clearances between the parts to be verified (using the Part Spacing
properties) when we do DRC checks. I can tell the DRC will report part
clearance errors, and >> sometimes it won't.
Still open, filed. Severe.
>>4. Ultiboard getting painfully slow after forward annotate
>>Whenever
I do a forward annotate from Multisim, Ultiboard gets very, very slow
and I start experimenting connection issues (connections between the
planes and traces running >> into them are intermittent)
Unknown status.
>>5. Wrong forward annotation list
>>The
modifications list that pops in Ultiboard when I do a forward
annotation rarely shows the real modifications. Most of the time it's
full of items that weren't changed.
Still open, filed.
6. Footprints name editing issue (Ultiboard)
When
I edit the name of a footprint in Ultiboard, pressing the delete key
generates a popup that ask to delete the package instead of simply
deleting the next character in the name
Still open, filed.
>>7. Connectivity check issue
>>No
earlier than this week I discovered on a real board that the
connectivity check doesn't report errors for a trace that is connected
by a single pixel (which can't, of course, represent a physical
connection)
>>8. Capacitors, inductors and such displayed value issue
>>I've tried to explain that one several times to technical support. Let me try to put it simply:
>> - when one places a capacitor on a schematic, he usually wants to see its VALUE displayed
we NEED to use only parts from our corporate database since they
contain custom fields information such as the part number, the price,
etc.
>> and we use the automatically generated BOM report to create our order files
when I place a capacitor from the corporate database on a schematic
page, it displays its NAME property, not its value. We have to use the
part number as a name
>> for our parts since there is many capacitors of the same value but with different characteristics
>>Now,
the only way to do this, according to NI, is to open the part
properties, deselect display value, and enter a the capacitor's value
in the Label field.
>>It
works, for sure, but let me tell you that it's not what I call a
productivity gain, even more so that several of the boards we design
uses tens and even hundreds of capacitors of
>>different values. It's painful to do and it's very error prone.
Still open, filed.
>>11. Toolbars won't stay in place!
>>I
reorder my toolbars time after time, after time, after time I use
Multisim or Ultiboard. Sometimes they are displaced even when I come
back to the office the following morning!
Still open, filed.
>>17. Vertical and horizontal swap error in Footprint Edit Mode
>>In the footprint edit mode, you'll notice that the horizontal swap command actually does a vertical swap and vice versa.
Still open, filed.
>>18. Clearances aren't always transferred from Multisim to Ultiboard
>>When
you edit the clearances of a net in Multisim, the changes doesn't get
transferred if this is the only modification that was done on this net.
If you change a connection on the >>net, however, the clearances get
transferred properly.
Unknown status. Severe.
19. When using the map pins tool, the pin mapping isn't saved properly.
order).
New. Severe.
FEATURES
>>9. Part symbols gets ugly when flipped horizontally
>>Not
a big deal, but still can't be for a professionnal product: when I flip
parts in a schematic, the pin numbers and names get misaligned
Still open, filed.
>>10. Part selector improvement
>>We
rely heavily on the user fields to carry important information about
our parts such as the price, part number, etc. I can tell that it would
be very usefull to see those fields displayed in the part selector.
Still open, filed.
>>12. 3D data
>>3D
is a great feature of Ultiboard. However, it would be a lot more useful
if it would be possible to place basic shapes in other plans than X-Y
alone
Still open, filed.
>>13. Power sources, grounds and offpage connectors
>>We
usually need to rename the powers the give them more meaningful names
such as 5V, 5VIsolated, etc. instead of VCC, VDD and such (the same
holds for the grounds, the >>offpage
connectors, etc.). Actually we can't copy those objects without losing
the name!! It means that we have to re-type the custom name each time,
which, again, can very easily leads to errors.
>>For the same reason, it would be great to be able to copy wire segments that carry a net name.
Still open, filed. Important feature.
>>16. Can't specify Reference Designators with more than 1 letter
>>When
you create a new family (or you want to change an old family, for that
matters), you can't specify a default reference designator with more
than 1 letter (ex. TR? for >>transformers)
Still open, filed.
>>15. Plane Z-order
>>We
often need to place a plane within a plane (per example a +5V area on a
layer that is entirely covered by a ground plane. Since there's no
defined z-order for the planes, the last one that was created is the
one on top. No need to tell that it creates a few headaches.
Still open, filed.
