Multisim and Ultiboard
branch currents abm voltage source
How do I access the current through the resistor in the ABM voltage source?
(6,377 Views)
I think I'mma answer my own question.
What I did was get the voltage across the 5 ohm resistor and divide it by its resistance. the I() function doesnt hold for other circuit elements aside from voltage sources or inductors. Is there any way I could model my ABM source when the resistance varies (like a potentiometer).
Are there other ways to link an element's parameter (resistance, capacitance) to the abm source? All I could find from the multisim user guide is voltage.
(6,364 Views)
One way to get the current is to insert an independent voltage source with a value of 0 V. This has no effect on the circuit otherwise but allows access to the current value.
Lynn
(6,354 Views)
Hi Lynn,
I tried your suggestion and still cant manage to get the I() function working. This is what I did.
(6,348 Views)
I do not have Multisim so I cannot help with problems specific to that.  When I run this in my SPICE program it works fine. Note that the controlled source is set to V = I(V5).
Lynn
(6,332 Views)
Accepted by topic author controlswhiz
I finally managed to access the current through the resistor. Others may want to see "Referencing Currents" in the Multisim Help.
(6,319 Views)
Я не могу это симулировать
что за аргументы V,V,3 ???
(269 Views)
