08-25-2017 04:29 AM
Hi, I'm making a simple audio amplifier using only transistors, the R3 1k variable resistor controls the gain of the amplifier, but when simulate not matter what value is set on R3 the bode plotter is the same. what can i do for analyze the gain and phase for different values of R3?
Is the bode plotter working only in the transient of the circuit ?
08-31-2017 03:58 PM - edited 08-31-2017 03:59 PM
It is actually changing, but it will only show the values of the initial circuit.
Check this out:
5%(1kΩ) VS 100%(1kΩ)
Just run the simulation again to get the plot of the new value.
Kudos are welcome 😉
09-01-2017 12:54 AM
Thanks a lot. I feel a little silly just run again the simulation. now im using an AC sweep instead of the bode plotter for the plots and all work fine.
Thanks Again.
