Multisim and Ultiboard
asking about design
Please give me some instruction How I can make design of electronic plate with  similar topology
Thank you
(4,841 Views)
Hi there!
If you have created the circuit in Multisim, you can simply transfer it to Ultiboard. Ultiboard can automatically creat the paths for you, or you can do it manually also.
You can create boards without the circuitry design in Multisim previoulsy. Here is a link to the whole manual of Ultiboard: http://www.ni.com/pdf/manuals/374488a.pdf
If you don't have time to explore the manual, just search for videos and such, you'll get the basics in no time.
Daniel.
(4,729 Views)
Hello Daniel. I dont have problem with  making of electronic plates. The problem is the design of the  same topology . I make plates with ordinary traces, but now I want  make plates where have Cu in all free plate( in ordinary plate have Cu only in trace) I hope that you will understand me Thank you
(4,660 Views)
Hi there!
Sorry for not noticing that for the first time! What you are searching for is called powerplane. I found a description about creating powerplanes here: http://web.alfredstate.edu/albaflr/Fall07/ELET7404/PROJECT%5CGnd-plane-ulti7.pdf
Hope this solves your problem!
Have a nice day!
Daniel.
(4,621 Views)
