01-30-2008 06:24 PM
01-30-2008 08:37 PM
Thanks for your information. I have been there done that. The BJT Model makers ask for a bunch of information that isn't necessarily listed in the text parameters on the the Datsheet, but is contained in the curve data charts. These charts are not easy to read and the values on the graph can be interpreted 5 different ways. This doesn't help when trying to create an accurate model of a component.
If you have a different way of creating models in this manner, please let us know how you do it. Maybe we are missing some information concerning this that you may know that can help the rest of us.
Thanks for any info in advance.
01-30-2008 10:46 PM
************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * * Modeling services provided by * * Interface Technologies www.i-t.com * ************************************** .MODEL 2n3055 npn +IS=2.37426e-14 BF=129.119 NF=0.85 VAF=31.1252 +IKF=0.990922 ISE=2.47498e-10 NE=1.89002 BR=1.01252 +NR=0.924456 VAR=254.624 IKR=2.70227 ISC=2.47498e-10 +NC=2.90624 RB=3.66609 IRB=0.1 RBM=0.1 +RE=0.000352673 RC=0.0764459 XTB=1.34801 XTI=1.07207 +EG=1.206 CJE=9.03089e-08 VJE=0.513954 MJE=0.59999 +TF=1e-08 XTF=1.36696 VTF=1.02605 ITF=0.987296 +CJC=5e-10 VJC=0.400243 MJC=0.410238 XCJC=0.803124 +FC=0.661216 CJS=0 VJS=0.75 MJS=0.5 +TR=1e-07 PTF=0 KF=0 AF=1 * Model generated on Jan 24, 2004 * Model format: SPICE3
01-30-2008 10:55 PM
Try that,mapping 1-collector 2-base 3-emitter.
q%p %tC %tB %tE %m
or click on show table, is easier.
02-01-2009 01:47 PM
This is a link to a very useful excel tool for modeling any transistor from its datasheet
http://www.analogservices.com/excel.htm
02-02-2009 12:59 PM - edited 02-02-2009 01:00 PM
To address one of your original questions, "q%p %tB %tC %tE %m" is the model template tells Multisim how to connect the a BJT. Multisim replaces %p with the RefDes and %C, %B, %E with the nets connected to the respective pins on the transistor and %m with the model name. However, you don't need to worry this at all because the Component Wizard creates this line for you.
I still think that the easiest way to create models is by using the component wizard. I hope these pointers will help you.
I have tried the Component Wizard and have been able to create the transistors based on your given models and they seem to simulate fine. I hope this helps. If you are confused about a particular step of this process, please let us know.
