Multisim and Ultiboard
Writing gain as a function of input frequency
The circuit I need to simulate uses a current controlled current source, with a gain function that depends on the input frequency. Is it possible to represent this using Multisim? If so, how?
(2,105 Views)
I may have found a workaround using CCVS --> Laplace Function --> VCCS. Is the S parameter in the Laplace function defined as jw (w should be omega)?
(2,074 Views)
Yes, that is correct. The angular frequency (w) is equal to [w=2*pi*f]. Which is the same as omega.
Pamela G
(2,067 Views)
