Multisim and Ultiboard
What is the release code for Multisim 8 Student Lite?
(7,053 Views)
When you first install there should be a button that say something like "Get Release Code" on the main screen where your signature code is. Select that and it should take you to where you can get the release code. If that doesn't work, then you will have to goto to NI's Multisim site and look there. I saw somewhere on there where you could get release codes for older versoins of Multisim. If you have not uninstalled Multisim properly and have exhausted all your installs (I believe based upon my 2001 Version, that it is 3 installls) then you will have to call them or e-mail them to get it.
Every relaease code is different based upon your serial number and signature code so no one can just give you a release code and besides that would be unethical (maybe even illegal) to do such a thing.
I hope this helps because I belive this is the only way to do it.
Have a Nice Day
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(7,052 Views)
well I didn't see get release code anywhere...all it says is enter release code.
(7,045 Views)
O.K. Goto http://www.electronicsworkbench.com/support/reg_all.htm and fill out the form there and see if you can get the release code from that.. If this doesn't work then you will have to call them or e-mail them to get it.
This is about all the options I have for you. I hope you get your code and can get up and running. Good Luck
Have a Nice Day
(7,041 Views)
Thanks for that website link Lacy.  I hope it works.
(7,038 Views)
Your Welcome. It may take a while (unless they have changed it) to receive it by e-mail. I think it took at least 24 hours for me to get mine the last time I had to do this (which was quite a long time ago).
Have a Nice Day
(7,033 Views)
