09-29-2015 09:11 AM - edited 09-29-2015 09:28 AM
Any idea?
I use Multisim 14
09-30-2015 01:58 PM
I ran this replica of your circuit, to make sure there were no errors with your connections, and it ran perfectly well, try the file that I sent and see how it behaves, if it gives you the same result then you'd either have some configurations set incorrectly, or there could be something wrong with the installation of your software. That said the default configurations of the program work just fine for this, so I'm a bit unsure right now what could be causing this behaviour.
09-30-2015 05:40 PM
I restored to default settings and it is ok now.
04-19-2020 11:24 AM
Hi, what default settings did you change?
I have the same problem now.
