10-17-2011 05:24 PM
I would like to use the Digital Waveform Generator. I have Student Version 11.0. I followed the below instructions.
I don't have the same toolbar listed in this doc..
http://zone.ni.com/devzone/cda/epd/p/id/5926#toc1
Is this because I have the student versions of Multisim and Labview or am I just being obtuse?
Thanks for your help!
10-20-2011 03:07 PM
Hi montech,
You should be able to use LabVIEW instruments in the student edition of Multisim. The file has to be saved to the following path C:\Program Files\National Instruments\Circuit Design Suite 11.0\lvinstruments.
In version 11.0, the instrument toolbar is on the right side of the window.
Hope this helps.
10-20-2011 10:50 PM
I did save it like this:
10-20-2011 10:57 PM
And It just isnt here! I appreciate any help. I just dont understand whats wrong.
10-21-2011 08:21 AM
If you click on the LabVIEW symbol on the toolbar in the right, you will see the LabVIEW instruments. Take a look at attached screen shot.
11-05-2011 06:01 PM
As I said the instrument isnt there.
01-03-2018 03:23 PM
I am also having the same issue. I'm trying to do this tutorial in MultiSim 14.1. I've saved the file to the proper location, and it is not showing up in the Labview instrument menu. I'm not sure where to go from here. I need to generate a pulse to test my circuit.
Mike
