Multisim and Ultiboard
Unlock Circuit Restrictions
I am trying to use some multisim problems for work, but do not have the unlock code for the circuits. Does anybody know where I can find this?
Jay
(6,400 Views)
BTW is ver 9
(6,394 Views)
Jay,
Are you using a non-Education version at work?... because non-EDU versions will not show the Circuit Restriction command, it is built-in the EDU versions. If this was the case then you need to unlock it first on a EDU version, save it, and then re-open it in your normal Pro version.
In case you are using a EDU version also, then you need the unlock code from the last person that lock it. The password is embedded on the file itself, is not a separate file.
Nestor
(6,381 Views)
Its for the problems located on the student disk. I didnt know if there was an unlock code for the teachers to view the faults.
(6,368 Views)
Jay,
Please tell me the specifics of the versions to understand better where the problem is... for example, the textbook CD for students, has sample files with a ".mst" extension if I'm correct, in which case they are meant to be open only by that specific edition of the software.
So I guess, what I want to know, is the complete name of the software CD in which you find these files, and the complete name of the software package (Multisim I mean) in which you are trying to open it. Plus the extension of the filename please.
Respond back with those details and I'll check it out...
Nestor
(6,362 Views)
They are .ms8 extensions, they are off the principals of electrnics circuits disk.
(6,358 Views)
