11-13-2006 11:21 PM
11-14-2006 08:35 AM
In some version, if you used the ‘Board wizard’ to setup your board as a single sided, you will get this message upon starting the router. To work around this, setup your board as a double sided board. On the spreadsheet click on the “Nets” tab, there should be a “routing layer” column, double click in this field and uncheck the layer you do not want to route on. If you use the Ctrl or the Shift key to select multiple nets, when you change one field all highlighted nets will also inherit the setting.
11-15-2006 10:12 PM
