08-04-2007 10:21 PM
08-05-2007 07:20 AM
I read up on the technolgy files. You can use them across designs. It it simular to Multisim's Save Simulation Settings function. So you can select what options you would like as a default in the current design project save it and load it as default in the next design project. I will post what the manual says about this and you can decide if this is what your looking for. The only thing is I don't know what options are changed for the one's already there yet. At least if you create your own you already know how Ultiboard will be set up each time you load it.
You can save the technology specifications from the current design into a technology file. This technology file can be used to import technology settings into another design.
To save a design’s technology specifications:
08-05-2007 07:33 AM
I may not have really answered your question with the above post. I have not found a way of retaining previous settings on starting Ultiboard other than the technology files. Both Ultiboard and Multisim seem to start each time with a pre-set default and I don't think that can be changed. The only option I can see is the technology files in Ultiboard and the Save Simulation Settings in Multisim.
I hope this helps somewhat. If Nestor, Max, or someone else has a better option please let us know.
Have a Nice Day
08-05-2007 07:57 AM
08-05-2007 08:00 AM
08-05-2007 08:46 AM
I don't know. Are we talking about 2 different programs? I am referring to Ultiboard and If I am wrong I apologize.
If it is Ultiboard, then I did an experiment and I will let you decide what to make of it. I loaded one of your board designs and then I used the Save Technology to save your setting to a file of my choosing. I then loaded one of my designs that I use for testing. Erased all copper. Loaded the tech file I just created and re-routed my board. It seems to me that it followed all your setting when routing my board.
Let me know your thoughts.
08-05-2007 09:07 AM
08-05-2007 09:34 AM
08-17-2007 08:27 AM
Hi Chris,
Ultiboard does not have the option to save default Ultiroute settings at the moment, I will create a feature request for this. Right now, you have to manually load your technology file every time you start Ultiboard.
