Multisim and Ultiboard
Trouble programming PIC MCU with assembly
I have never used the MCU programming feature in multisim before and because I recently started playing with assembly, thought it really nice not having to spend money on building a test board and simulate it instead.
The problem is that the PIC I'm using does not seem to get programmed. Followed the wizard to set it up after picking it from the library, created the project with main.asm code under it, it builds but does not end up in the controller.
However, when doubleclicking U1, under the code tab there appears no code selected. Not sure if that indicates a problem. On the other hand, selecting MCU in the circuit view and going to MCU (U1) code manager takes me to the code, so it seems linked.
I added images in the attachments, hopefully they help you help me:)
Thank you
Message 1 of 1
(943 Views)
