Multisim and Ultiboard
Transferring License To Another Device
I would like to know if there is any way I could use my NI Multisim license on a new device. Unfortunately, the laptop which I had installed Multisim on had a hardware failure (hard drive). Is there any chance that I can still use the same license on a different device?
Thanks.
(3,773 Views)
You may simple use your serial number after installing the software on your new computer to activate it. If you tried using both installations simultaneously then you might run into problems, but as you describe this, you should have no problem.
(3,728 Views)
Thanks for replying. Unfortunately, I had lost the CD. Any idea where I can download version 11 from? That was the specific version I had for the license.
(3,709 Views)
I think this is it!
(3,701 Views)
