‎01-28-2018 01:04 PM
I would like to know if there is any way I could use my NI Multisim license on a new device. Unfortunately, the laptop which I had installed Multisim on had a hardware failure (hard drive). Is there any chance that I can still use the same license on a different device?
Thanks.
‎01-29-2018 07:53 AM
You may simple use your serial number after installing the software on your new computer to activate it. If you tried using both installations simultaneously then you might run into problems, but as you describe this, you should have no problem.
‎02-01-2018 01:16 PM
Thanks for replying. Unfortunately, I had lost the CD. Any idea where I can download version 11 from? That was the specific version I had for the license.
‎02-01-2018 07:56 PM
I think this is it!
