Multisim and Ultiboard
The Probes do not work correctly in this version of Multisim
Multisim 14.1, Surface 2 laptop, Windows 10
Updater indicates Multisim is up to date
Refers to attached PDF of circuit
My Probes in this version do not work visually the way they should.  I can drag a probe out of the bin and try to place it on a wire, but instead the measurement window follows and turns yellow when it is close enough to the wire to measure.  (note that it is not touching).  The probe arrow itself is off to the side somewhere and is not predicable.
This seems to be all of the probes.  Very distracting and makes the use of the differential voltage probe next to useless.
This was not a problem in version 13.
Message 1 of 1
(1,027 Views)
