12-11-2007 12:49 AM
12-11-2007 08:27 AM
Hi Kerms,
Could you please attach the circuit that contains that subcircuit if possible, so I can look into it further.
12-11-2007 12:21 PM - edited 12-11-2007 12:28 PM
12-11-2007 05:51 PM
I have an option for you to try. I am hoping you saved the orginal schematic of the internal connections for the subcircuit block or this won't work. Delete your current subcircuit from the schematic. Goto PLACE>Hierarchy Block from File. Browse to where you hopefully saved the original schematic and click on it. This should place a new subcircuit on the schematic with all the lines labeled correctly.
What I don't understand is the copy a paste thing you mentioned. With a subcircuit the lines are automatically labeled when it is created and you shouldn't have to do anything with it. As long as you have the original schematic saved you can place subcircuits or hierarchy blocks in any print without having to cut and paste.
I hope this helps.
12-11-2007 08:21 PM - edited 12-11-2007 08:21 PM
12-12-2007 08:06 AM
The basic difference between an SC and an HB is that the SC is stored within the circuit file and an HB is stored as a seperate file. This makes it easy for a user to use the HB in other designs as well, whereas the SC is tied to a specific design.
Hope that answers your question.
12-12-2007 05:51 PM
02-22-2009 03:50 PM
"The basic difference between an SC and an HB is that the SC is stored within the circuit file and an HB is stored as a seperate file. This makes it easy for a user to use the HB in other designs as well, whereas the SC is tied to a specific design."
I have found that a subcircuit can be created, edited for pin names (can't seem to get the pin orientation thing down yet though), and then copied to the clipboard. Then another circuit can be brought up and the copied subcircuit "pasted as subcircuit" in that new circuit. Be prepared though, because the windows do a lot of funky things before you finally end up with the outline of the subcircuit in the intended circuit -- it's kinda scary the first few times around. Then, if you want to use the subcircuit again and you use the same identifier, you also get the option of pasting another instance. I just did this because I needed the 74hc193 counter, but the Multisim model has a small error -- I just created the chip via the databook and made it a subcircuit.
