Hello. I am simulating a circuit with a ci 555 in stable mode and 5 ci's 555 in monostable mode. Each ci 555 monostable is activated by a switch.
It turns out that when I play the simulation, the simulation time is microseconds, and when I press all the keys at the same time, it starts counting in seconds. However, to study the operation of my circuit, I need to press one key at a time, watch the output, and only then press the next key.
Does anyone know how to change the simulation speed in this case? Because I already changed several parameters like TMAX, but I can only change the start time of the simulation, not its speed. The altered parameters were spice, in relation to the error tolerance, also without changing the simulation speed.
