11-09-2007 08:02 PM
11-10-2007 03:31 PM
Multisim has a motor but I don't see a quadrature encoder. The only problem I see is with the quadrature encoder as it partially works in the mechanical area on a rotating shaft. There are no moving parts in Multisim or any other spice software that I know of. That would have to be simulated by creating a circuit in the electrical area that would mimic the mechanical function of the quadrature encoder. This could be a huge task and I wouldn't even begin to know how to accomplish that.
Multisim's motor has a pin on it that electrically represents the RPM as a voltage that is read on a multimeter. I have found that it doesn't always work as expected in all applications. You would just have to try it and see it it works for you by adjusting it to your motor specifications.
This is all I can tell you and if someone has an idea I would hope they would post it for you
11-11-2007 06:56 AM
11-11-2007 09:59 AM
11-11-2007 12:31 PM
I do not have a real answer for your last question. It may be possible, but I just don't have any information as to how it can be done. Maybe the NI team can read this post and answer the last question as they probably have better information on that than I do about how to enter mathmatical expression into Multsim. I do know that Multisim will allow mathmatical expressions in cetain instances, but I do not know how or where you might be able to enter that information. They may even know of a way of doing what you need with one of the source signals or maybe even a database component that could mimic the behaviour you need. I just don't know that information or I would definitely tell it to you.
Sorry that I haven't been much help here, but I can only do what my knowledge allows me to do.
