08-06-2011 03:18 AM
Hi guys,
I have a problem with LM324 simulation.
Here is my circuit:
I simulated it but the output of the opamp was just a DC signal which is theoretically incorrect.
Pls help me to find out where the problem is.
Thank you.
Solved! Go to Solution.
08-07-2011 07:18 AM
Check up connections of power supplies with the GND.
08-07-2011 08:55 PM
Thank you for your answer. The +12V power supply was not connected to GND causing the incorrect result.
regards,
