Multisim and Ultiboard
SIMULATION
Good day to you all,i want to ask for help in understanding the meaning of (-r-) when i am measuring for resistance of a silicon diode?
(2,244 Views)
Highlighted
The -r- reading in the Multimeter indicates an overrange. That means that the actual reading is greater than the Multimeter's setting. For example, if you are measuring a 1.5 GOhms resistance but the Ohmmeter overrange resistance is 1 GOhm, the display cannot show the number and the -r- is shown. The same happens for voltage or current readings.
To change the display settings just double-click the Multimeter and click on Set. Once you change the Ohmmeter overrange resistance to large enough value, you should be able to see the diode's resistance.
Camilo V.
(2,229 Views)
Thanks a lot Camillo V,it worked well and sorrry for the late response,m grateful for your support.
(2,199 Views)
