08-04-2007 10:41 AM
08-04-2007 11:51 AM - edited 08-04-2007 11:51 AM
O.K. I have investigated this. I will present my solution first and then comment later.
1. Goto the File Menu. Go Down to where it says Load Technology. Click it and select one of them.
2. When the dialog box comes up uncheck all boxes except Design Rules and Autorouter Options.
This should get your board routed. I am not quite sure what the technology files actually do (I will find out though), but they don't seem to be changing your original configuration (or at least I couldn't see where they did).
I hope this helps. There may be other solutions that may be better than miine and if anyone knows of a better option please inform the community.
Message Edited by lacy on 08-04-2007 11:58 AM
08-04-2007 12:17 PM
08-04-2007 12:48 PM
Yea, if your leave all the boxes checked it pops DRC errors because I think it is changing some of the options from what you have set. The thing is if you uncheck all them execept the Design Rules and Autorouter Options, I don't see where it changes anything about your current configuration (I don't fully understand it either, but it seems to work). Anyway, you are right about 2 things. The autorouter not kicking after 2 tries or whatever you have set and the default should not have much problems in such a small design. I could understand it maybe if you were designing a complete PC or something that large. Most of the time it does good, but on occasion it seems to get stuck.
Maybe on such an issue, Nestor or Max may have a better take on this.
08-10-2007 03:04 PM
It is really difficult to predict what Ultiroute will do, just because one setting work for one design it does not mean it will work in another. I looked at your board and was able to get a complete route by changing any of the following settings:
I see your problem with the rip up and I am not sure what is happening behind the scene but I know that Ultiroute will eventually exit, your board takes a really long time. Typically, I will let the router go as far as it can and when you look at the bottom of the Ultiroute screen and see that the number of route complete is not increase, you should let it run for another minute or so and just manually stop it.
08-10-2007 03:37 PM - edited 08-10-2007 03:37 PM
Message Edited by kittmaster on 08-10-2007 03:37 PM
08-28-2007 12:24 PM
Hi Chris
I am not saying that you should change anything to your design, all I am trying to say is that when the router failed to complete, you may have to modify certain settings, which may/may not help. If what I suggested is going to create a problem in the manufacture process, then you should not touch those settings.
Your question as to why the router does not exit automatically is not easy to answer since we are not able to tell what it Ultiroute is doing. Basically, the router will exit when it runs out of things to do and in this case it sees options so it will keep trying. In general, when you see router get to a point where it is having trouble you should give it a few more minutes and then manually stop it. In my experience, even if you let it run for a long time, the router may give you one or two more traces but if you stop it and manually route the trace, it will be faster. I will ask R&D to look into this issue.
