11-13-2019 11:31 AM
when i tried to simulate the circuit,there was an error in simulating and it is displayed that it is due to singular matrix.
i could find any error..in the circuit and kindly help me to solve this..if possible..please correct and attach the copyof it i will be very thankful for your help.
11-13-2019 03:48 PM
You are connecting two "Out" together! that's why Multisim was referring to the pin 5 connection issue.
Also, the stimulation parameters needed to be tuned. Kindly check the file
11-14-2019 01:22 AM
is there any option to club or add those two outputs and giving to the transistors in the circuit.thanks for your solution regarding my problem explained above.
