07-28-2019 10:40 AM
Hi, I have encountered a problem with my Multisim circuit. I have thrown in a spdt switch to vary between 2 voltages which are; 5 v and 3.3 v respectively but the problem is that when i toggle the switch to the 3.3 v terminal, I'm getting a voltage on the other terminal and i cant understand why. Can someone help me rectify this please?
08-12-2019 07:01 PM
Hi Antoines,
With the first switch position, you are actually reading an open with the multimeter (you are not actually reading a signal) since you are measuring a from an open terminal to ground. The multimeter can measure anything since it is an open terminal, y real life you can be measuring noise at that moment. I wouldn't take into account that value.
Hector M
