05-24-2007 02:44 PM
05-29-2007 02:27 PM
Do you have the SPICE model that was converted from the IBIS model? Maybe I can try to get that model work, otherwise you will have to create a circuit that emulates MAX489 using components from Multisim master database.
05-31-2007 09:14 AM
05-31-2007 09:32 AM
05-31-2007 11:34 AM
06-05-2007 11:29 AM
Multisim uses both SPICE and XPSICE simulation engine and there should be plenty of resources available on the Internet relating for these topics. Here are links where you can find the manuals:
SPICE:
http://esaki.ee.boun.edu.tr/~talays/spice/spice.pdf
XSPICE:
http://users.ece.gatech.edu/~mrichard/Xspice/Xspice_Users_Manual.pdf
The models you sent me will not work as is, there are minor syntax issues that needs to be modified and for it to work and here is a list:
1. No 'Param' statements were declared but a couple of statements uses a variable as a value, they did defined variable and was commented out, I guess they expect you to manually change it. The variables I am referring to are RTR and RTF:
Look for these statements:
*DEFINE {RTR}= 53.731k ;2.68V/1.44ns
B3 300 850 I= V(830) > 1.2 ? 0 : V(300,850) / {RTR}
Just replace RTR with the value like this:
B3 300 850 I= V(830) > 1.2 ? 0 : V(300,850) / 53.731
2. There are many instances where xy_array were used and unfortunately, Multisim does not support this syntax and you need to split the table into x_array and y_array separately.
For example the original model looks like this:
xy_array = [
+ -6.000 , -2.360
+ -5.000 , -2.360
+ -4.000 , -1.800
You need to change it to this:
+ x_array [-6.000 -5.000 -4.000 …..]
+ y_array = [ -2.630 -2.360 -1.800 ….]
3. You need to remove the some commas in the model
Original model:
+ fraction = FALSE, input_domain = 0.0,
Change to:
+ fraction = FALSE input_domain = 0.0
4. There are several duplicate subckt names declared and you should make them unique. I simply added an extra number at the end.
The attached file contain the modified model and test circuit, I am not sure what this component is suppose to but I connected some power sources to it and was able to simulate without an error.
I hope this help.
Tien
06-09-2007 12:11 PM
