02-28-2022 06:40 AM
Hello, I'm trying to recreate these results...
for this circuit
Here is my, circuit in multisim
But the signal formed in the oscilloscope is nowhere near the desired results. What am I doing wrong here?
12-29-2022 05:05 AM
Hi StudentGoh,
I have some questions that need to be clearly understood for me.
1. Did you create this project by yourself, or you took it from Multisim examples?
2. Can you share "faction generator -XFG1 and XFG2" paraments with us for replication?
Also, I checked, there is a different voltage compare with this part of circuit through which you created yours. From the right picture you can see that the opamp varies around -15 to 15 volts, but there is not any negative voltage in there.
Regards)
12-30-2022 07:50 AM
Вот простой вариант, выдающий нужные вам результаты. Частота, амплитуда, фаза, смещение устанавливайте по своему желанию
01-01-2023 03:11 AM
заработал 0,5 модулятора
для быстроты симуляции частоты увеличены
01-01-2023 07:28 AM - edited 01-01-2023 07:34 AM
-попробовал идти дальше, получил такую картинку из Вашей симуляции
