Upon opening and closing Multisim, the issue occurs a lot less often.
Removing the voltage regulator gets rid of the issue entirely. This is a bit contradictory, considering the that the voltage regulator should be supplying a more stable voltage than the 12V battery.
I will continue to investigate why this behavior is happening.
