Multisim and Ultiboard
Reply
Problem with ratsnest and (probably) custom pad shapes
Highlighted
I am having a problem with ratsnest showing a connection not made, even though there is a trace running to the pad. We have experienced this previously at my company, and in both cases it has involves a custom SMT pad.
There are traces that are connected but the ratsnest still exists and the Connectivity Check fails:ratsnest2.JPGratsnest1.JPG
On some designs I can make it happen, but then it goes away on Connection Check:
It seems that the problem persists on larger, more complex designs.
I have attached a neutered version of the board I am currently working on that is having the problem. Anyone have any ideas on how to fix this?
(1,275 Views)
When you post a design, please inform us on the version of Ultiboard you are using.
I am using V10.1, so I could not open your design.
Sorry I can't help.
Succes!
Stressed user
(1,262 Views)
Thanks for trying. For others, this is version 13.0
(1,258 Views)
about your led
I remeber having a similar problem on a capacitor with custom shapes.
Can you try renaming your custom pas with 1 and 2, not using letters A and C?
Be sure  to change your schematic symbol as well
succes!
(1,198 Views)
stressed,
(1,190 Views)
