When running a transient analysis, you can go to the Output tab and select Add Expression. In the expression, you can write time where ever you need and make the complete expression. When you will press Simulate, it should show you the output for that expression.
Your expression would be written as i1*(time^2) + 34 + i2*(time^3)
I am very new to Multisim too, i just want to ask how can i draw a function using Pass Transistor Logic (PTL) and show the body effect with NI Multisim?
