05-15-2020 02:58 PM
I am trying to do a parameter sweep simulation (DC operating point) on this simple voltage divider circuit:
The value of resistor R1 is given by an expresion which depends on parameter "T"
Running two separate interactive simulations for T = 0 and for T = 50, I get the following results, as one would expect:
The problem comes when I do the parameter sweep simulation (DC operating point):
I am leaving the analysis options as default.
I get the following results, which are incorrect:
I have also realised that the result I get is dependent on the initial "T" value I have on the "circuit parameter window", which I find to be weird.
For example, if I change the T value to 50 and run the same parameter sweep as before, I get the following results:
Can anyone spot what I am doing wrong?
Thank you
Regards
David
05-17-2020 07:01 AM
Hello, I tried reproducing your error in Multisim 14.2. I copied all the settings in your simulation profile but for me it works as it should, regardless of the initial value for T.
