‎11-20-2017 09:34 AM
‎11-21-2017 08:15 AM
Hi Bert,
With a bit of searching I came across the following:
http://www.anale-ing.uem.ro/2009/2009_a9.pdf
It is a nice simple example of a PID controller.
When looking on Figure 1.b you will see the schematic.
This schematic has 5 different parts:
Please keep in mind that the input is the error signal. To get this signal you need to subtract the desired value from the actual value.
Have a look at the following:
http://www.electronics-tutorials.ws/opamp/opamp_5.html
Lastly I made the following example:
https://www.multisim.com/content/bFq4rZYn2YGh9Yggo2McnA/pid-control/
(You may want to switch around the reference and input temperature depending if you have a positive or negative feedback)
This should be enough to allow you to create your PID controller 🙂
Kind regards,
Natan Biesmans
‎11-22-2017 03:05 AM
Thank you Natan. This is a great example.
