04-24-2021 07:40 AM
TRYING TO OPEN AN EWB FILE WITH MULTISIM 10, APPEARS A QUESTION : FILE LOADING OPTIONS -> COMPONENT POSITIONS -> ORIZONTAL, VERTICAL SCALING..........WHICH PRISES WE PUT THERE?
04-27-2021 10:33 AM - edited 04-27-2021 10:34 AM
Could you please describe the issue in more detail or provide some screenshots?
Are you trying just File>Open and select the file?
Best Regards.
05-04-2021 03:46 AM
That's a screenshot of the message
05-18-2021 09:03 AM
1. Open the file in the usual manner. The File Loading Options dialog
box displays, with the default Horizontal Scaling and Vertical
Scaling settings of 120, that is 120% of the original spacing.
This indicates that there will be 20% more space between the
components than in the original .ewb file. This is because the
components in Multisim are larger than in Electronics Workbench 5.
2. If desired, increase or decrease the spacing between the components by
increasing or decreasing the Horizontal Scaling and Vertical Scaling values.
Best regards.
