Multisim and Ultiboard
Reply
Noise generator Multisim
Hello, I am student and new to Multisim software.
I'm trying to generate noise (thermal) across a current source. Can some one  please suggest me how to do it ?
I have found thermal noise genarator for voltage source . How can I use it across current source?
Any suggestion will be appreciated. Thank You.
(55 Views)
Hi Shetty14,
use the Thermal Noise component: "Thermal noise source. Produces the white noise generated by a resistor due to thermal effects."
Place>>Componetnts>>Signal Voltage Sources>>Thermal Noise
Adding an appropriate series resistor to the model will result in a "noise current" of corresponding rms value.
This noise current you can add to another current by applying parallel connection.
Best Regards,
NI TSE
(25 Views)
