Multisim and Ultiboard
Night Timer
You will be required to design a 'Night Timer' system.night. The
timer should have four 7-segment LEDs i.e. should count up
to 59 minutes 59 seconds in increment of 1 second. Nosferatu
can pause the timer if he spots a beautiful lady while
joyriding. He can also reset the timer any time he wishes to.
You will have to design an electronic system with:
1. Four 7-segment RED LEDs. (his favourite colour)
2. One PAUSE button and one RESET button to pause and reset the timer as needed.
3. Nosferatu starts cycling once it gets appreciably dark. You need to use and configure a Light
Dependent Resistor for that purpose. (Note: Multisim does not make provision for LDRs so to
simulate your design you have to use an Opto-coupler and potentiometer combination to represent
the LDR).
4. You need to use a step-down transformer as the system will have a 230V AC supply (Nosferatu can
generate electrical power from one of his special organ) and the timer should operate on 9V DC.
5. You MUST ONLY use the following components in your design: Power Source, Transformer, Opto-
coupler, Potentiometer, switches, LED Display, Resistors, Capacitors, Transistors, Diodes, Basic logic
gates ICs, Decoders, Timers, Counters and Flip-Flops.
6. You CANNOT use Programmable ICs, Micro-controllers or Multi-Function ICs to design the system.
(2,527 Views)
Highlighted
Hello, thanks for response
what it has to do with MS???
thanks a lot
Michael
(2,514 Views)
hi,since im new to NI instruments and multisim..i cant really understand how to create the above mentioned circuit for night timer. can you please send how this is done as soon as possible because a short of time and have submit it by saturday. thanks
(2,444 Views)
I am not the forum master but I think this forum is rather dedicated to problems concerning working with Multisim and Ultiboard, i.e. problems which occur when using these programs. It is probably NOT dedicated to get electronic circuits working, rather to capture them with Multisim and Ultiboard.
There are lots of forums and groups on the internet covering problems with circuit design.
Also, there are many publications from NI and others covering the basics of making schematics, performing simulations and creating boards with Multisim and Ultiboard.
(2,433 Views)
