07-18-2011 10:22 PM
Hi All,
I am a new user for Ultiboard, I trying to modified an existing PCB by placing components directly in Ultiboard . "Ultiboard doesn't correct any errors when you don't have a schematic". Kindly, I was wondering if anyone can take a look at this board and tell me if it is a working board. \
Thank you,
XAYA
07-18-2011 11:07 PM
07-19-2011 01:05 AM
1. Tools>>Netlist Editor
2. Net>>New>>1
3. Pins>>Add>>LED1,PinA + R2,Pin2
4. Net>>New>>2
Net>>New>>...
07-19-2011 07:03 PM
Hi supsup,
Thank you for your help, Im still having problem with the PCB. I can still see red circles on the corners of the traces and cannot have a clean pin connection with the trace. Any advise please? Do you know a good tutorial I can use?
XAYA
07-19-2011 11:57 PM
Hi xaya,
Whether you have created all nets? Attach your last Ultiboard file, please.
07-20-2011 12:31 AM
here it is
Thank you
Xaya
07-20-2011 01:02 AM - edited 07-20-2011 01:03 AM
Hi xaya
1. View>>Spreadsheet View
At creation of the list of nets you have made many errors. Check up a widht of traces. Use Help file.
07-20-2011 02:15 AM
I changed the trace width maximum to 1mm and clearance 0.1000mm but Im still having the same errors. Is there a default rule (for beginners) that can be used to avoid errors for basic work?
Thank you.
Xaya
07-20-2011 02:19 AM
Sorry missed the file 🙂
07-20-2011 02:27 AM - edited 07-20-2011 02:28 AM
Now at you other errors. You have incorrectly made the list of nets. Rectify all errors!
