10-08-2016 09:37 AM
Hi there,
Who can help me ? I have a problem with my installation of multisim. The problem is that my pc instal the circuit design but the multisim application do not instal with it so I can't open it on my pc.
thanks.
10-10-2016 03:20 AM
Hey KevinVO,
Could you tell me a couple of things, where did you install the circuit design from? A link a CD? If a link could you post it?
What operating system do you have (specific)?
Kind Regards,
Natalia
10-11-2016 06:21 AM
Hi Natalia,
I installed from this link: http://www.ni.com/gate/gb/GB_ACADEMICEVALMULTISIM/US .
My operating system is Windows 10 (x64 bit).
Thanks for your answer.
Kevin
10-11-2016 06:41 AM
Hey,
And have you isntalled the 32 bit or 64 bit version ?
The 64 bit version is not supported on Windows 10
http://www.ni.com/white-paper/52818/en/#top
Kind Regards,
-Natalia
10-11-2016 07:02 AM
Hey,
I can not choose between the x32 bit or x64 bit for Multisim ? Is that normal?
Kevin
10-11-2016 07:33 AM
Hey,
Could you verify the location All Programs » National Instruments » Circuit Design Suite xx.x » Multisim xx.x.
doesn't contain Multisim?
Check out the tutorial:
http://www.ni.com/tutorial/14581/en/
Kind Regards,
Natalia
10-11-2016 08:03 AM
hey,
Multisim stands not in this list ?
Kevin
10-13-2016 02:05 AM
Hey Kevin,
I have just downloaded from the same link and run the installation, worked all fine for me.
You could try to remove the software or fix the installation
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Let me know if it helps,
Natalia
10-16-2016 08:28 AM
Hey,
If I see between my list of al my programs i can not find the setup. so remove is probably not an option.
the only thing that is installed on my pc is the "setup.exe" file.
Kevin
