Multisim and Ultiboard
Multisim
Hi there,
Who can help me ? I have a problem with my installation of multisim. The problem is that my pc instal the circuit design but the multisim application do not instal with it so I can't open it on my pc.
thanks.
Message 1 of 9
(3,853 Views)
Hey KevinVO,
Could you tell me a couple of things, where did you install the circuit design from? A link a CD? If a link could you post it?
What operating system do you have (specific)?
Kind Regards,
Natalia
Message 2 of 9
(3,819 Views)
Hi Natalia,
I installed from this link: http://www.ni.com/gate/gb/GB_ACADEMICEVALMULTISIM/US .
My operating system is Windows 10 (x64 bit).
Thanks for your answer.
Kevin
Message 3 of 9
(3,807 Views)
Hey,
And have you isntalled the 32 bit or 64 bit version ?
The 64 bit version is not supported on Windows 10
http://www.ni.com/white-paper/52818/en/#top
Kind Regards,
-Natalia
Message 4 of 9
(3,805 Views)
Hey,
I can not choose between the x32 bit or x64 bit for Multisim ? Is that normal?
Kevin
Message 5 of 9
(3,802 Views)
Hey,
Could you verify the location All Programs » National Instruments » Circuit Design Suite xx.x » Multisim xx.x.
doesn't contain Multisim?
Check out the tutorial:
http://www.ni.com/tutorial/14581/en/
Kind Regards,
Natalia
Message 6 of 9
(3,797 Views)
hey,
Multisim stands not in this list ?
Kevin
Message 7 of 9
(3,795 Views)
Hey Kevin,
I have just downloaded from the same link and run the installation, worked all fine for me.
You could try to remove the software or fix the installation
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Let me know if it helps,
Natalia
Message 8 of 9
(3,761 Views)
Hey,
If I see between my list of al my programs i can not find the setup. so remove is probably not an option.
the only thing that is installed on my pc is the "setup.exe" file.
Kevin
Message 9 of 9
(3,734 Views)
