12-06-2017 11:03 AM
I'm attempting to prevent students from copying multisim files from each other. LabVIEW has a revision tracking feature for VIs which has been very helpful at catching cheaters. Does Multisim has such a feature? or some other method of determining file user origination/modification data?
Solved! Go to Solution.
12-11-2017 04:46 PM
Multisim doesn't have a revision history for circuits, but there is some information about the file you can get under the File > File Information option.
You may also set a variety of global- and circuit-restrictions from the Options menu, but none of these provide a revision history
Also on Multisim Live you get the ability to see if a file was copied from another, so that may be something useful.
