Multisim and Ultiboard
Multisim Live - Grapher
 I'm trying to demonstrate gain using an amplifier and the Grapher in Multisim Live.
  My input signal is 10mV peak - my output is about 5V peak.
  I can only seem to set one Voltage scale in the grapher window, though - either my 5V signal goes way outside the screen, or my input signal appears as a flat line.
  Is there a way to set an appropriate Voltage scale for each probe being graphed?
Thanks for your help.
Message 1 of 8
(2,992 Views)
Accepted by wt_higo
Hello wt_higo,
Yes, unfortunately Multisim Live doesn't have that function yet.
I believe in near future it will be fixed.
__________________________________________
The best way to thank, is to give KUDOS
Message 2 of 8
(2,926 Views)
Oh well - thanks for letting know.
All the best
Message 3 of 8
(2,896 Views)
Oops - that was confusing
...I was logged in as my student account rather than my teacher account 🙂
Message 4 of 8
(2,894 Views)
given the limitations of Multisim Online, what you could do to help you out is to plot an expression rather than the node voltage. This allows you introduce a gain or attenuation of the node voltage that is exact, you know is there and you can account for in the explanations. This will give you a second axis on the right and the possibility to adjust the waveforms indpendently much how you would do with the channels of a physical oscilloscope.
Message 5 of 8
(2,877 Views)
  this sounds really useful, but am I right in thinking I need the "full" version of Multisim Live to access it?
...I don't see the expression plotter in the Analysis and Annotation menu.
Thanks.
Message 6 of 8
(2,870 Views)
You could be right, I only have a premium account for testing.
Message 7 of 8
(2,866 Views)
That's a shame...unless my department can get a premium subscription by collecting crisp-packets, I think I'm stuck with the standard version...
Thanks anyway.
Message 8 of 8
(2,858 Views)
